my 93 cb has 196435 milez and when put my hand near muffler to check exuast flow..cuz i know sometin its wrong...it flow out rough lilke car go over bump..its not smooth...and I can hear it goes bup bup bup from rear of exausdt when i press a gas slowly and easy.
Exhuast flow not smooth
Don't quite understand what you're describing...but perhaps the muffler has a leak, or could be the engine not running right, which can give odd exhaust sounds.Opal Metallic Green '92 LX 2dr manual, 181k miles, '94 prelude VTEC wheels for summer (steelies with snow tires for winter), Omni-power struts/springs, and other junk
Originally posted by wed3kisnt the popping noise the engine missing?
i would say you have an exhaust leak somewhere...maybe an exhaust gasket missing from a connector piece in the exhaust..or it could be your header leaking...you'll have to explain to use a lot more about this problem for us to come up with a sound explanation.
im betting most likely though its a leak between exhaust linkages. how long ago did you get your exhaust replaced?Audi A4 2.8 Quattro Sport
We need more information such as, is it stock exhaust, does it run bad (other then just the noise), is it rusty, etc. If you do not have a cat on it, it will tend to backfire because there isn't a whole lot of back pressure.
I donno if its the correct way of checking for leaks, but when i wanted to see if i had a leak, I took a paper towel and covered the exhaust, and it'll force the air out of where the leak is (if there is one).
sorry guys. my english is not good..its not about exhuast noise...what Im trying to say is that my exhaust flow is rough (unevenly flow out)...the flow is not smooth.
damn iono how to say this..but its like a fan blowing at u..u will feel an even smooth air blasting at u..my exhuast doesnt flow smooth out like that..but it cut and flow cut and flow unevenly. ..ya meean.
MY 1n2 CB7
When you say not smooth when its coming out it doesnt feel like full flow? If you notice an increase in exhaust noise you could have a leak as specified. If it feels like not a lotta air is comin out and such could be something clogging the system like your catalytic converter or muffler. Hope that helps out a lil
Originally posted by colslaw87you mean your exhaust flows out in puffs, not a constant flow.
could it be that i need a Valve Ajustment.?
MY 1n2 CB7
Thats how the engine naturally is. Your exhaust valve closes shuts the exhaust for a second or so then it opens back up. Thats basically somewhat what it does hence why your exhaust flow shouldnt be smooth all the time.
