Question about turning
    Everytime I turn, it makes a loud clunk sound than after that when I drive straight it makes a buzz sounds..is it my CV-joint?..I know I saw this question was in other thread, but I can't ask any question becuz I'm under 30 post..can you guys help me out to fix this clunk sound and buzz...
    if it's making a clicking sound while turning i would definetly say its your cv joints. as far as the buzzing while going straight i have no clue. maybe someone else can chime in with some help.
      First of all, where do you think these sounds are coming from? A constant clicking sound, depending on your speed when turning, coming from the front close to the tires indicates a worn cv-joint. But you say you hear a clunk?? could be suspension related maybe?
      And the buzzing sound... I have no idea.
      Members Ride Thread
        I had the same thing. Its something to do with the axle shaft. I don t know exactly but I replaced it and no more clickin.
        No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
          Crawl under the car and look at the boots of the cv shafts if they are busted open and then you will see your problem.
            like BRUNO said......check the cv boots, but also look at your tie rods. Grab the tire and try to rotate it, if it feels loose, it could be your tire rod. the cluck could also be the steering gear. As far as the buzzing....maybe the wheel bearing? not too sure on that since i haven't had that go yet. good luck finding the problem.
            "Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways-Jack Daniels in one hand-chocolate in the other-body thoroughly used up-totally worn out and screaming "WOO HOO!, What a Ride!
              Well I agree with the clunking might be the cv boot; as for the buzzing maybe a motor mount?
              South Texas M_thaf_cka, that's where I stay!
              Check out my Frost White CB
              http://www.cb7tuner.com/vbb/showthre...ight=SpdJnky93
                the CV boot was replaced..the sound is comin from the front right side
                  i replaced one of my cv joints 1 year ago and its makin noise again
                    One of the Members I know is a mechanic and if you PM him I am sure he will respond. His member name is Nightmare. Look for him. It can't hurt.
                      Loud Clunk might mean a rear ball joint.
                      My car had that sound last year. I thought it was the CV joints and replaced them. Then the next day my rear left ball joint went and the car was on the ground. Get all your ball joints checked.
                      The buzzing could easily be your tires. Recently, I had a loud buzzing sound when I was driving. Sounded like it was the CV joints again. However, I replaced my old Goodyear Hp's tires with Bridgestone Potenza G009's, and my car is now really quiet. No buzzing or grumbling sounds.
                      DEVOTE
                      FS: Lokuputha's Stuff
