When I bought my car the speedomiter did'int work. At first I thought that it was the cable(but I now know its all electranic.), so I took my dash apart and it was all working. So just the other day I was working on my engine, and I noticed my speed sensor was disconnected(duh!!!), but before I put it all back together I want to know if there is a way to check if my speed sensor is broken.(don't want to have to pull it all back out if it does'int work!)
Broken speed sensor
I have been having an intermittent problem of my speedometer working on my 91 LX w/5 speed. It works then it stops then it works. It doesnt happen all the time though. Also, when the speedometer does start working, it seems like the engine picks up a little. The check engine light comes on every once in a while but will reset after the car is turned off. I havent pulled the codes from the ECM. I read the article in previous posts and it seems that the VSS sensor is going out. Any other suggestions?07 Kia Sportage (Her car)
91 Accord EX (My car)
04 BMW R1150RS (My bike)
