what little mods can i do to my cb with out spending a lot of money like bigger honda injectors mainfold ec i want slite or no mod to the actuale part
i'm kind of confused by what you mean with the injectors and manifold statement. are you suggesting those as mods you can do?
usually the first 3 basic mods you can do is intake, header and exhaust. you can advance the timing (it's free ) but make sure you don't advance it too far or you'll start knocking.
bigger injectors will do nothing for you. the only time you need bigger injectors is if you're running forced induction.
Originally posted by eludedU95i'm kind of confused by what you mean with the injectors and manifold statement. are you suggesting those as mods you can do?
A great one is modding your stock airbox by either cutting the entire bottom off {} and removing the ducting/resonator OR making a cold air extension into the box.
You can do some weight reduction, there's alot of info on that here. Take out your A/C, P/S, and C/C for starters (what I've done) and you can go alot further.
Fill all your motor mounts w/ polyurethane. A simple experiment is to remove the front/torque mount, cut 4 pairs of maple or oak shims/wedges, and wedge them into the reliefs of the mount, making it solid. You'll like the results and it's easy, I did mine last Sunday
Bypassing the T/B coolant line is another good one too
Dan
yes
Originally posted by arthaccordya thats what i ment i alreaduy know about headers intake ec but im looking for other stock honda parts that will fit with no modification that will give me more powerAudi A4 2.8 Quattro Sport
if u want stock honda parts, you can use an f22a6 intake manifold, it has dual runners that open up around 3500rpm, if you do this you should also get the 92-93ex ecu, its the pt6 it goes with the intake manifold and has differant fuel curves, but if you gonna do that also get the 92-93ex cam, you'll have a good setup there with those three things gain a decent amount of throttle response, best of all you can get all this from your local junk yard
Spark plugs man. You got to get Good ones.
I'm running Bosch Platinum +4's and I love them
I get way better gas mileage (28-33 MPG mostly in the city.)
And the power is SOOOO much better than the stock ones I had.
Get a bigger cam for about 6-10 more HP. I think the EX's of our car had a bigger one but ask around.
Originally posted by arthaccordwhat little mods can i do to my cb with out spending a lot of money like bigger honda injectors mainfold ec i want slite or no mod to the actuale part
instal them on your car, and run low 14's
incase you didnt know, the turbo manifold on DSM's (eclipses, talons, lasers) bold onto the F22 head.
