I was just getting gas for my car and my friend said it is bad to pump gas because the gas truck was there pumping gas at the same time. Said something like you get all the bad gas or something.
Getting Gas
The myth is that there could be air bubbles that are caused from the filling from the truck to the underground tanks that could get in the engine and cause damage. Rule of thumb is just try to catch is before of to wait until after the truck is done so that the old and new gas is mixed. It doesn't really matter just preferences.
Originally posted by accordoholicI was just getting gas for my car and my friend said it is bad to pump gas because the gas truck was there pumping gas at the same time. Said something like you get all the bad gas or something.
haha you get the same gas that hes pumping in, it doesnt matter.
if you're paranoid then figure out the schedule when the gas truck comes in, and get there after to fill up with fresh fuel.
The only issue I can see is that the truck is stirring up the gas in the underground tank as it fills it. That means any sediment that was at the bottom is now floating. When the truck is not there, that sediment remains undisturbed.
If you're going to a quality station, they're less likely to have a significant amount of sediment... so I wouldn't worry. If you went to some crappy cheap-o place with the same two foreign guys running it 24/7, THEN you might have reason to worry!
MOST stations should filter their gas at the pump anyway. There are some that are supposedly better than others (Sunoco and Exxon, I think I once heard? Never confirmed that). If any don't, it's probably the cheapie no-name ones.
Newer electronic pumps are temperature compensated, so temp doesn't matter.Originally posted by eightyfour84i heard its best to get gas late at night or early morning when its the coolest out cause its denser then. but dunno about the truck thing.2003 Maxima SE Titanium Edition
1993 Suzuki GSX1100F 136bhp
Not sure what you mean by "airproof", but all pumps have air eliminators, so air is NOT metered.Originally posted by 93spooncb7air bubbles wouldnt matter at all those tanks arent air proof and when u pump the gas into your car if you had it its just gonna sit on in the top of your tank lol, that has nothing to do with it2003 Maxima SE Titanium Edition
UST's are not pressurised. When testing them after installation, we can only test them to 5psi, which isn't nearly enough to provide the flow required for a busy station.Originally posted by Spartan1987Your friend is wrong.
It doesn't matter because the truck hooks up to the underground tanks which are pressurized, and it is then distributed to your car.
Not just straight from the truck.
Gas stations are either a pressure system, with pumps in the tank pressurising the lines, or a vacuum system, with suction pumps in the dispensers.2003 Maxima SE Titanium Edition
All pumps have internal filters, and they don't have a bypass. Slow flow usually means a clogged filter, or a tripped leak detector on a pressure system.Originally posted by deevergoteMOST stations should filter their gas at the pump anyway. There are some that are supposedly better than others (Sunoco and Exxon, I think I once heard? Never confirmed that). If any don't, it's probably the cheapie no-name ones.2003 Maxima SE Titanium Edition
