im getting 4 flashes and then a quick 5th flash. would it be a 05 map sensor...and if it is should i buy new or junkyard
cel
http://www.cb7tuner.com/vbb/showthre...&highlight=cel Its a code 41. That should help you out with all your codes and such.
O2 Sensor
Code 41
Primary Heated O2 sensor heater circuit
Open or short in Primary O2 sensor heater circuit, defective Primary O2 sensor heater circuit.
Check for proper supply voltage to the heater. Measure the voltage between the yel/blk wire (+) and the or/blk wire (-) on the O2 sensor connector. There should be battery voltage with the ignition key on (engine not running).
If there is no voltage, check the circuit between the main relay, the ECU and the sensor. If the O2 sensor fails any of theses tests, replace it with a new O2 sensor.
Good luck
Jeff
