H23 transmission
    H23 transmission
    Hello,
    I have an H23 tranny on the way and was wondering exactly what modifications you need to do to make the H23 transmission on the F22.
    Thanks
    You may have to tap two holes if its a manual tranny like the h22. Are you getting auto or manual tranny?
      its a manual tranny. Do I have to tap two new holes a retap existing ones a different size. Thanks for your help.
        Can somebody please help me. I really need to know what to do.
        THanks
          Transmission Mounts:
          For the 5-Speed you will to use a 10x1.25mm tap to tap the two unused holes in the Prelude transmissions case. Before you can do this the holes need to be enlarged with an 11/32" drill bit... get a drill bit that is made to drill through metal! Remove the two studs from their old location, and install them in the location you just drilled and tapped. Then you can mount up the Accord's tranny mount on the Prelude transmission.
          I remember there was a pic of this somewhere but the h23 should be similar the the h22a.
            thanks a ton I appreciate it alot.
