LSD over Non LSD
    LSD over Non LSD
    Whats the difference in LSD & non-lsd?
    Accord for sale: check classifieds!
    4x100/4x114.3 Wheels: Check Parts for sale!
    equal power to both wheels with lsd, non lsd gives one wheel quite a bit more power than the other
      LSD = Limited Slip Differential
      I'd say the simple answer is it distributes the power to the ground evenly to both wheels. It greatly helps in traction so in instances such as auto-x, when your going through a turn the power is distributed to the outside wheel rather than the inside to pull you through the turn all while sustaining optimal traction. It also helps in draggin as when you launch both wheels will eat into the ground providing more support for [fast&furious] more traction for the hole shot /[fast&furious]. So instead of you trying to do a uber cool burnout and only putting down marks from one wheel, you'll put down two
      In the question of should you get or not, of course you should. I don't think there's no reason why you wouldn't want a lsd for any type of application.
      I think that pretty much explains it unless i'm a lil wrong on something, in any case someone will chime in and explain further.
      EDIT: Yea..LSD FTW !!! lol
      I love the bouncy...it's great...
        you covored it i was just trying to say it in the easiest way possible and i agree with getting it lsd FTW
          LSD is definetly the way to go... alot of times i only have 1 tire spinning and i only weigh 120LBS so i dont think im makeing a differance..... i need one bad, but they are so expensive.
          The sig name is new from a local forum. sorry to confuse anyone.
          My Member's Ride Page
          The Accords gone but I will forever belong to CB7Tuner
            if you're getting an engine go HMO and its 300 extra$ for the LSD. deffinatly worth it.
              its worth it you get what you pay for
                he sells the phantom slip thats a bad move gettin one of those they break easy or unexpectedly . Get a real lsd quiafe.
                  I dunno. I'd say it's worth it if you have something worth putting it on. I mean, a f22a motor with i/h/e, definitely not worth it, spend the money better.
                  Shift_BOOST
                  BOOM!
