So I tested the tps and found that it was at .53 volts. After reading over the diy i set it to .32 (since it is a bored tb). I was curious though as to what problems can happen if it is not set correctly. My idle was not jumping at all, but sometimes the idle will suddenyl drop, but I am assuming that is because I have a vacuum leak on the manifold. Any thoughts?
Tps sensor setting off
