Ok now first off my car is currently running stock ecu and stock injectors. BUT IS NOT BOOSTED, turbo is in but it is just blowing into the engine bay. I took off the first charge pipe, and diisconnected the wastgate, so it wouldnt push the turbo as hard when daily driving. (if you need me to explain lemme know
Anyways, I am running hardline copper 1/4" lines to couple to the 14b dsm stock line which is the similar size, I was wondering if I should use a valve to slow the oil flow?(I have it already but not installed) Could this be why my oil is spraying out the j pipe on the turbo? WaC.
)Anyways, I am running hardline copper 1/4" lines to couple to the 14b dsm stock line which is the similar size, I was wondering if I should use a valve to slow the oil flow?(I have it already but not installed) Could this be why my oil is spraying out the j pipe on the turbo? WaC.
