Ok here's the deal. I'm trying to help AccordAnimal out with his 92 accord LX. The guy he bought the car from said that occasionally it would just die and sometimes it would start right up and sometimes it would take a while. He said the hotter it was the worse the problem was. Adam(accordanimal) drove the car around and to work, approx 20-30 mins. When he got to the parking lot at work the car just died. It wouldn't restart...just cranked. He managed to push it into a spot. We both figured it was the Main Relay since that's all we had read about on here. I picked one up and replaced it, and it's still not starting. The car cranks and cranks, but it doesn't even "pop" or "sputter" like it's trying to run. (You know, when you crank and it kinda starts and then dies, it doesn't do that...it just stays at a constant crank.) I checked and the fuel pump is turning on. What else could it be? I'm thinking spark, how can I check that? Just pull the plugs out and set them on the top of the engine and watch for spark? To check for fuel what is something easy I can do? Should I just pull a fuel line off of somewhere and see if fuel gets pushed out when we try and start the car? Any help would be appreciated guys! Thanks!! The battery was just replaced yesterday before he went to work.
Replaced main relay, still won't start!
When you turn the key once, do you hear the, "HISS" of the main relay/fuel?
I dont mean to crank it, i mean, one turn of the key is the "on" position no? you should hear the main relay click...
...if you dont hear that, maybe you wired the main relay wrong? im stumped too...new battery...tested the alternator?
NO! dont start the car with exposed spark plugs/wires...or an exposed fuel filter line...
Edit: Do you have an aftermarket alarm system all up integrated into the main relay? just a thought...Last edited by Accord13&BA4; 04-27-2006, 04:31 PM.
1990 Accord Lx F22a1(Daily) SOLD - will be missed
Originally posted by Accord13&BA4When you turn the key once, do you hear the, "HISS" of the main relay/fuel?
Well we checked the spark and no spark was showing. So what did we do? The same thing that any CB7 tuner would do. Take the distributor off of the 92 ex(his cb7 that runs fine) and throw it on the 92 lx(the one that we couldn't start) What do you know it starts right up! We went to the junkyard to find a replacement, but unfortunatly there is only ONE CB7 there! and someone already had yanked the dizzy But at least the problem is solved and there is a new main relay in there.Quote:
Originally Posted by SuperTuner12010
But the cat robs my horses.
1991 Honda Accord LX Sedan w/5 speed transmission
Originally posted by kaponeyou dont have to change the hole dizzi just change the igniter coil its beter to buy that new anyways ....Quote:
Well I just decided to bite the bullet and pick up a new one. I found it for $100 BRAND new off ebay. It's coming from Cali so I have to wait about a week for the part cuz they are using Fed-Ex...someone shoot me!Quote:
