Help
    Help
    I'm throwing a code 20 with my h22 (ELD). Anybody knows how to fix? It also hesitates and hiccups randomly and wont engage vtec. No other cel's and no other problems. I've been installing a alarm, will that do something? But i disconnected the alarm and its still doing it.
    Electrical Load Detector is Code 20 or thats what it says. Sounds like something inside your alternator. You sure thats the only code your throwing? I would recheck your wiring.
      Any wiring problem will throw this code? This code just seems so vague.
        Could be but im saying check your wiring for VTEC and such my bad didnt make that clear.
          Still no vtec, the ELD code went away. But i the ecu flashed a code 3 map sensor code. And it will go into vtec but it'll cut out at 6500. Limp mode? But i'm throwing any codes. Will a vacuum leak or a bad map sensor make it not go into vtec?
