hey guys, new to the forum, gonna see if yall can help me out i have a 2000 jeep cherokee and was wondering if i could fit just any kind of 18'' wheel on it, such as tuner wheels, and what problems i would face in gettin some to fit........i dont wanna pay a lot for truck/suv wheels
18s
as long as the backspacing and bolt pattern is correct, I don't see why not. I think most wheels for jeeps are over-engineered to cope with of road abuse. So if you get these 18's, they should work but I wouldn't go tackle the Rubicon trail with them or anything. You also need to check the weight rating on the wheels. I'm sure you could make 18's fit on anything but if they were designed for a sport compact and you slap them on a Ford F350, you could have some major problems. Also bear in mind that wheels can be re-drilled to fit for you, but at a cost.1992 Honda Accord DX
Coupe 5spd
2.2 liter I-4 (code: F22a1)
125hp @5200 rpm 137 lb/ft @4000 rpm
(\__/)
(O.o )
(> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
Try a mitsubishi montero most prone to tip over. And yes 18s will fit. If you can put 18s on a honda you can put one on a jeep. Heres a pic of the srt8 its somwhat close to the jeep grand cherokee just newer =D.Originally posted by 19accord92jeeps suck, once you start turning fast enough, prepare to dieeeeeee
they actually do somewhat "suck", just because they are very top heavy and the engines are known for their problems. In the jeep grand cherokees, i've seen 5 different jeeps in at Midas at 100k miles for engine/tranny mounts going bad. Generally, speaking their not the best vehicles, although i am still looking at the grand cherokee and the commander.Originally posted by 93accordexcoupethat happens in cb's.
jeeps dont suck at all. u suck at driving if that happens to u
18's will fit, and so will 20's, i've seen them on jeeps before, and as stated above the srt-4 has some pretty nice/big rims on it.Audi A4 2.8 Quattro Sport
Jeeps are great .. You can certainly fit 18s. I personally wouldn't go wider than 8" though; you'd need some pretty wide tires to make 9" wheels look right. Not to mention, you'd need a pretty big fender gap to keep the tires from rubbing. So, just throw some 18x8s on there. You need a 5x4.5" lug pattern (or 5x114.3 for those metric fans), and a 3.5"-4" backspacing would probably be best (4" is best for your suspension life, but closer to 3.5" is going to look better, so maybe a 3.75"). Also, that's the same lug pattern as a Ford Ranger, so keep that in mind if you're gonna search eBay (there's way more options for a Ranger).
2¢
whether it will rub or not, you need to put the wheels on and find out for yourself.
