Install
    Install
    How hard would it be to remove a motor and install another one Because about 3 days ago my cousin through a rod through his block and i got to install another F22A4 in its place
    Thanks
    The swap probably couldn't get much smoother. Just swing by your local auto parts store, grab a Haynes or Chilton manual for the car, and follow the instructions. Unless you're planning to open the block up, there really isn't anything that's going to complicate the process too much. Being your first time though, plan at least two full days for this, in case you run into any problems.
    2¢
      just to clue you in, if anyonetells you to take the motor out without the tranny, dont listen, its easier to do the whole package.
      turboed cb7 baby
        well, that depends on the guy's ability.....if he's a noob to working on cars, he'll spend more time fucking with the axles and shit than he should and it WON'T be easier.......it's less of a headache, but you can loosen the side tranny mount enough to angle the motor and wiggle it out...easier on a lift because you can be under it but i've done it in the driveway too........it's less headache to leave it attached and pull it out, but it's more work......a lot will tell you to pull it through the top and it's easier to come out the bottom
          hanses manual is butter, better yet one of the honda tuning magazines had the removal and install of a f22a and f22B, i think it was jan-apr 05, on of those issues.
          CB7 Architect
            go to the honda dealership and request a manual for the accord from that year, if youre lucky they can get you one, its alot more detailed....
            anyways, should be a very easy swap, once you get all electrical lines/excess parts off, its pretty much a starightforward plug and play...and if you can, do the transmission with the engine, youll thank yourself later
            1993 CB7
            2001 BB6
              you better take digital pictures so you can see what goes where. there a lot of wires and shit connecters and shit. good luck with that.
