How much for the timing belt and waterpump
    ??? around how much would it cost with labor and everything. I was on my way to the Green acres meet and as im pulling to stop in my friends shop in queens it died right there so i left it there and they should let me know the price tomorro but i wanted to know roughly how much im looking at here.
    I didnt want to go to the meet in my cousins 96 civic or my friends 98 integra so i just went home to die.
    1993 Accord EX
    2011 Subaru STi
    $300-$500
    I think my mom's '97 Odyseey job, has a F22 engine in it, cost like $400 and change from the dealer.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      yeah i would say about 350 at the dealer
      Members Ride
        or you can do it yourself with all the parts OEM from majestic honda for 130 shipped.
        thats if you can do it yourself
          The job is gonna be done in my friends shop where right where it left me im also changing the head gaskets, brakes and alternator
          1993 Accord EX
          2011 Subaru STi
            I phoned my local dealer two days ago for just that question.
            Timing Belt + Water Pump Job = $700
            Canadian $, BUT STILL OUT-EXPLETIVE RHYMING WITH CLUCKING-RAGEOUS.
            Are you guys serious about the $350 timing belt job??!?! I'm gonna phone some more dealers in the mean-time...hmmmm
            1991 Honda Accord EX (Canadian)
              Timing belt and water pump is always an expensive job... $130 for parts from Majestic Honda, which means $200 or more when you get it all from a shop (they make their profit, and often don't have cheap sources... Majestic Honda beats most prices around) Labor is fairly extensive, at least in terms of having to pay for it! The timing belt and water pump are VERY important parts, so if you're not confident doing it yourself, it's worth the expense to have a professional do it.
              Be sure to inspect your motor thoroughly... check the head and the block for damage. What broke on you? If the timing belt went, then you could be looking at damaged valves and possibly pistons. If your water pump blew, you could have a cracked block. Don't spend a ton of money on replacing parts only to find that your motor is badly damaged! Inspect it carefully first. You're better off buying a replacement motor if there is damage done...
                Ok theyre going to charge me 450 for the new timming belt, water pump, alternator, head gaskets, and cutting the rottors, i think thats a pretty good deal, the only thing is that im BROKE but since its my friends shop I dont have to pay him right away, im doing all these things now because ill forget to do it later. and then boom im left on the street. witch is pretty embarassing here in NYC.
                1993 Accord EX
                2011 Subaru STi
                  i say if you can do it yourself than you should do it
                  if you can't change the timing belt and water pump than
                  you should get a auto mechanic you can trust
                  i am getting my timing belt, water pump and rear motor mount
                  changed for about 150-175 or so it is way cheaper than the dealer
                  and have you guys tried this website http://www.hondapartsdeals.com/
                  it is a little bit cheaper than Majestic honda
                  H22 fund = 3000 hopefully soon My Member's Ride Thread
                  Canon XTI | 28-135mm IS USM | 18-55mm kit lens | 50mm 1.8 II
                    i was charged 370 for water pump: (removal/installation/bleed/fresh new coolant)
                    1996 Honda Civic LX 2009-2012
                    2012 Kia Optima LX 2012-2013
                      At Honda dealers around here I believe they charge $600-700 for a timing belt package, similar price range to a clutch job.
                        If you're going to do it yourself here is an OEM website:
                        www.hondaautomotiveparts.com
                        Get the following for a complete timing belt package job for typical 90-93 Accords:
                        - water pump
                        - timing belt
                        - balancer shaft belt
                        - front balancer shaft seal
                        - front balancer shaft seal retainer
                        - front crank seal
                        - front cam seal
                        - new timing belt tensioner, if original does not turn freely
                        - new tensioner springs, if original in bad shape
                        While you there, if you want you can:
                        - install new lower spark plug tube O-rings
                        - install new valve cover gasket kit
                        - install new distributor O-ring
                          :werd:
                          That's what I was quoted
                            i had a guy i know do mine for $150 bucks. i just had to provide the parts. he did my clutch a year before for $200.
                            "the J32a2 should be considered one of Honda's masterpieces..." Honda Tuning, July 2006
                              I got my car done at the dealer ship and it gost me 667$ cdn for everything
                              My Members Ride Page
