Releasing gas pedal
Mine does it but i think its the tune on my P28. My old F22A6 that was in there didnt do it as bad as my h22a. Usually i just ease off the pedal and its a lot smoother. It only happens whenever im gassin it and let off immediately to let the engine slow the car down but its like a small jerk.
Well when you do that the car immediately goes into a deceleration mode which is understandable...No pedal pressure makes the computer think you wanna stop so it decreases the amount of fuel/air going into the chamber which could cause that jerk. But if you gradually ease off you should be fine.
Check the pedal as he said. If not its the fork inside needs to be lubed up since that would be the only other places that it could squeek but your gonna have to bear with that until your next clutch change.Originally posted by The G-ManThat thing in the picture is the clutch slave cylinder. It is what pops out to disengage the clutch. Are you sure it is not the spring on the pedal assembly that is squeaking? Mine does, nothing is wrong.
