Window Issues
    Window Issues
    Hey guys,
    On my driver side front window the plastic molding is messed up. when i roll the window up all the way is pushed forward and off the track by the plactic seal thingy. any solutions??
    K here's my advice.............
    JUst to let you know that little plastic cap is the guide on the window sash and its called a window guide that circular half inch diameter thing on your window. I dont know where you can get one at though, but if it still getting pushed off track then check into getting a new molding for the window from a junkyard or something.
      lol im having that same exact prob man. i just raise the window slowly and it closes kinda good
      old accord
      http://www.cardomain.com/ride/2261780
        Order it from Honda. Thats the only place you can get them from i think. My buddy recently put one in his civic.
          my drivers side window does some crazy junk too. its like its too tight near the mirror and i have to push it a little to get it to close flat. may be the window tint...
          Formerly: sheisanonymous
            Originally posted by LiquidMercury
            any solutions??
            Yeah. Im having the same problem. What I do is guide it with my hands.
              My passenger window vibrates when it goes up only when it is wet. Wierd huh?
                Lube your channels and your railings that the window slides on on the motor itself. Use lithium grease it works wonders.
                  my driver side window does it to when i put it down. but i dont really have a problem wit it since it gos down without me pushing it down.
                    Mine does the same thing (tilts forward when rolling up). It needs a new window regulator to fix it.
                    http://froogle.google.com/froogle?q=...oogle&ct=title
                    ~ Viva la Roofnips ~
                    2006 Evolution MR 13.008 @ 106.7
                    2006 WRX Sti (still breaking it in)
                    1990 Honda Accord LX-T 15.6 @ 93
                      I seem to be having a similar problem, my Drivers window is very sluggish to roll down and gets stuck sometimes, when it goes up it vibrates quite a bit and does not roll all the way up, i guess i need to remove the door panel and do some cleaning and adjustment?
                        i ended up buying new run channels and a new motor/regulator. kind of expensive but i finally dont have to deal with that annoying wind noise at 70mph. well worth it in my opinion.
