Anyone know what the max safe psi is on a F22a1 with stock internals? currently running 8psi.
max safe psi on stock internals F22a1?
ok, nm.. I did a little more searching and found the answer to my questoin. Seems that 11psi would be the upper limit with a good tune and even then that might be risky.~ Viva la Roofnips ~
2006 Evolution MR 13.008 @ 106.7
2006 WRX Sti (still breaking it in)
1990 Honda Accord LX-T 15.6 @ 93
::claps:: see, you could have just done that in the first place...Originally posted by Mr. Evo IXok, nm.. I did a little more searching and found the answer to my questoin. Seems that 11psi would be the upper limit with a good tune and even then that might be risky.
mabye this whole not replying thing is a good way to encourage searching...hmmmmmmmmmmmm
Actually I searched prior to posting anything but I guess my search was too specific.
I was just looking at compression ratios for F22a1 and they are about as low as any honda motor made (8.8:1) so 11psi should really be safely do-able. I just checked out a pic of the stock rods and they dont look too bad either.~ Viva la Roofnips ~
