No SPARK Cyl.#3
    No SPARK Cyl.#3
    I feel like im getting a misfire. It hesitates going down the road pretty bad. With the motor running i went and pulled each spakplug wire to see if i got spark. Well, all of them have spark except #3. When i pull that one there is no change in how the motor sounds. Where do i go from here?
    Let me hear your input guys. I have a 1993 ex is that matters.
    Thoughts:
    Change cap, rotor, spark plug wires...if that doesn't work your dizzy might be taking a shit on you.
    No longer working on the cb. To much time and money has been put into it. Check my for sale thread where the whole car will be parted out.
      Get another sparkplug wire and test again.
      When you pull the sparkplug cable the motor should feel like its about to stall.
      If you do that and you're still not getting spark then check your cap&rotor.
      Make sure the rotor is tight, also check the condition of it.
      Check the inside of the cap for white residue...
      Do that and let us know how it goes.
        The rotor should be alright, or the misfiring would likely be inconsistent. Definitely check the wire and cap though.
          Or, see if JaK FRoSTWhiTE can come up and loan you his cap and wires, since he's not too far ...
            I have a used set with 180k on them.
            But where the hell is he from?
              swap wires with #2 or #4 see if the problem moves
              ~ Viva la Roofnips ~
              2006 Evolution MR 13.008 @ 106.7
              2006 WRX Sti (still breaking it in)
              1990 Honda Accord LX-T 15.6 @ 93
                He's in North Jersey. Seton Hall is a university out there (aka 'SHU', as listed in his 'location') ...
                  Oh Yes!
                  Good eye.
                  I knew it sounded familiar...
                    Good old fashioned tune up!!!
