i need a new clutch and i was think about a flywheel as well. ill prolly go with an exedy stage 1 and a 12lb flywheel but I kno with a lightened flywheel you gain a little bottom end power but in gaining that do u sacrafice any top end power
Flywheel
Originally posted by wed3kif my equation is right, you lose momentum because of less mass.
so trying to keep it in the powerband is a bit harder because the rpm's fall faster between shifts.
Sounds like you'd spend more time on the gas, and less time shifting.2003 Maxima SE Titanium Edition
1993 Suzuki GSX1100F 136bhp
Originally posted by Mikebecuase when u let off the gas it slows down a lot faster
If it slows down faster, you can get into the next gear that much faster.
When you want an engine to stay in a certain rev range, it's probably best NOT to release the throttle.2003 Maxima SE Titanium Edition
http://www.cb7tuner.com/vbb/showthread.php?t=46961
This should help as It will say I have the 12lb I usually shift at 3gs and I dont bang the gears (unless racing of coarse) rpms drop right at were the gear begains. Since the upgrade the car engages smoother than an automatic. Also inthe post someone wrote the stock one is around 15-20lbs mine weighed 28lbs BIG difference.Last edited by kricket; 05-22-2006, 08:57 PM.
Originally posted by mondojackalif it takes you that long to shift, then you are shifting like a grandma..
