Hey everyone looking in the market for some new wheels but have questions. Will a 15x8 wheel fit with a 225/50/15 tire ?
15x8 wheels
a 225 is about 8.9 inches. So it'll fit. But make sure you get the right offset. We had 225 on our race car at first, I think we had them on 17x8 wheels. It would rub on the inside when the steering was turned all the way. You'll need a wheel with the right offset Do a search on this site for "offset". I think, but am not totally sure that you need an offset in the range of 35 to 40 mm or they'll rub on the fender. Since you're getting new wheels, you might want to consider 16" wheels. I'd guess that 16x7 wheels are a better fit. There is more tire selection in 16s than in 15s these days.==========================
1991 Accord Lemons Race Car, "The Minnow" RIP
1993 Accord Lemons Race Car, "SpaceEx Starship"
Neuspeed Race Springs, Koni Sports, Acura CL Rear Sway Bar,
Adj Upper Control Arms -3.0deg front, -2.0 deg rear
M2A4 Trans, Cusco 1-way Limited Slip Differential, Stage 2 Clutch and 11lb flywheel. A4 Header, 2" exhaust all the way back, catalyst delete, delta 262 grind, glasspack muffler, PT6 ECU.
Acura CL3.0 Brakes Front and Rear, Raybestos St43 Pads, Redline 600 Brake Fluid
