So, I was doing my spark plug tube seals along with a valve adjustment and valve cover reseal, and when I took the rocker carriers off the head I noticed this interesting wear pattern on the intake rockers for cylinder 4 (closest to the distributor). It seems to be not making full flat contact on the cam.
The car's already back together and I never noticed any issues with assembly or even that it was out of adjustment more than the other valves, and the wear on the cam wasn't bad. but is there something else to be adjusted to make it wear flatter?
Obviously it's been like this from the factory, and has lasted 125k miles without any issues- i'd guess now that it's "worn in" there's no point to fucking with it. But I'm just curious if anyone's seen this before in factory engines.
