1993 Accord starting issue
    Car turns over, I replaced the main relay, Distributor, Coil, Fuel Pressure regulator, Ignition switch. Fuel pressure at fuel rail, however when I pull a couple plugs they are dry. No CEL.
    What can it be? What can cause the fuel injectors not to open, if thats the problem? I swapped out the ECU and fuel injector resistor box.
    Solved!
    91 Accord LX 5-speed
    93 Accord LX 5-speed
