Suspension problems
    Suspension problems
    I have a 93 sedan and its been drop for a year and change with 17 inch rims. I recently sold my drop and put the stock suspension back on. Now when driving the car pulls to the left very hard. Do you think it could be my tie rods or do I just need a wheel alignment or will dropping the car back down resolve the issue?
    Also will the struts of a 90- 93 prelude fit on a 93 ex sedan somebody said they will sell me their drop, Its is Koni yellows with sportlines. I just wanted to be sure it fits. Thanx!
    ~~~ Never Drive Faster Then Your Guardian Angle Can Fly ~~~
    Anytime you modify the drop/suspension on a car, a wheel alignment is needed. If it was your tie rod end, lift the car on a jackstand. The wheel(s) should not move side-to-side. It should simply roll...no play side-to-side whatsoever. If it does move side-to-side, it is your tie-rod end(s).
    1990 Accord Lx F22a1(Daily) SOLD - will be missed
      I would say you need an alignment bad before you mess up your wheels. On the struts im not sure havnt checked that out before.
        Yes, if you changed the springs and did not get the car re-aligned that is your problem. As was said, any time you change your ride height your car needs re-aligned if you care how it drives or how your tires wear.
