Gear oil drain plug
    Gear oil drain plug
    Could someone help me find the gear oil drain plug and also where I insert the gear oil at on my cb, do u guys have pics of it?
    "Cocaine's a hellava drug"
    Eh, transmission right? Well, look near the passenger wheel. Actually right on the other side of the fender. You will find a circular shaped protrusion at the bottom on the transmission, it will have aq square hole in it. I am pretty sure it is for a 3/8'' drive socket, stick the ratchet in there and unscrew it.
    Now for the fill bolt, it is up and to the left (looking from the passenger wheel in) from the drain bolt. This one is like a 5/9'', best to use a box wrench on it.
    Gary A.K.A. Carter
    [sig killed by photobucket]
      Also, to fill it up, attach a funnel to a hose and feed it down through the engine bay to the fill hole for the tranny. I used duct tape the attach the funnel to the hose. Mind as well use synthetic as well since you dont change it very often. Fill it up until it starts pouring out the bottom hole and you're good to go.
        Also if you have a MT, you will have to pump the tranny oil from the bottom, since there is no way to fill your tranny from the top of your engine bay.
        Hi
          how do u pump oil frm the transmission...im just confused.....just a newbie here...thanx though.....ohh yeah.......is it really required to change ur gear oil?and how many do u need?
            For manual trannys hondas use 10w30 motor oil. For best results use honda manual transmisson fluid(10w30) from your local honda dealer.
            jdmCITY.com
              This is a pic from a integra's manual transmission, however it's very close to whhere our drain and fill holes are:
              Also don't forget new drain and fill bolt crush washers!
                the drain plug is on the bottom edge of the passenger side of the tranny, its the only bolt that doesnt have a hex head, its a 3/8" drive hole that you stick a ratchet into to turn. to refill, there is a metal tube (supposed to have a rubber cap on it) sticking straight up from the center of the top of the tranny. its a breather hole, pull the cap off and push a rubber hose onto it and then a funnel into the other end of the rubber hose, and you can fill it from there. 1.9 quarts.
