Speed Sensor
    Speed Sensor
    Last night my sports shift light came on along with my check engine light. I jumped the codes and both state the speed sensor is bad. Are the sensors the same for 90-93? Napa shows a different one for each year (91,92) and Autozone shows 3 different ones. The price difference is $50 or more. The ones from Napa are 129 and 179 ( I paid that much for the tcu) I can get one from Honda for a 115 (takes 3 days to get here) but I will pay Napa extra 20 to get it today.
    T
    I need the info on this too. My speed sensor crapped out on me last night.. CEL and no speedo. I wanted to know the same thing if they're all the same 90-93 and if there is a difference between 5 speed and auto.
    Also, you can find them very cheap on ebay.. for less than $20 new.
      the actual sensor itself is swappable between 90-97 accords and 92-01 ludes, but the gear assembly that the sensor is bolted to is different between automatic and manual...
      if you buy the sensor from the dealer, i think youll get just the sensor... if you go to a junkyard, you could get the whole sensor/assembly/gear/etc for dirt cheap.
        Thanks. The sensor is all I thought I needed to be replaced. Is the gear assembly something needed as well?
          nah you dont really need it. i was just commenting that you could get the whole thing from a junkyard for less than you could get just the sensor for new...
            Ok I called Napa and they showed in the book that 90-91 are different than 92-97. I called the dealer and gave my vin and they only show one (78410-SY0-03) Which crosses over to Napa's number VSS626. Is this true has anyone with a 90-91 used one off a 92-97?
