anyone have A4 header on A1
    i jsut installed a4 header today..everytin went well..ecept i dont use any manifold bracket and the stock bracket on the downpipe doesnt align up. but everythin is botled tgoghter and it ran then white smoke appear in the engine...i probale have to torque everythin down again 2morw...for those who done it..any tips on this project
    MY 1n2 CB7
    did you use a new gasket?
      I just did this a few weeks ago. I just bolted it to the head and used the a4 down pipe but the cat was cut off so i just made a cut to match the down pipe with my a1 pipes and had it welded. So my set up is a4 header with a4 flex pipe its cut off right after the hanger then welded to the a1 cat. hope this help. It did help on the top end a little, its got more get up and go on the high end for sure. Good luck.
        thnx...I used old gasket but no leak bt/w head and manifold yet.lol..the o-rings are new tho...
        the a4 flexpipe is bent a liltle when i bolt evertyin down.. I jsut need to fix the leak b/w manifold to downpipe and reroute the 02 and im good to go.
        MY 1n2 CB7
          Yeah ya know what ! i bolted mine together before i installed no gasket either.. Also no leaks But i think i know what ur talking about now. There is a tab for 2 bolts on the flex pipe i never got them to go back on, its was about 1/2 in off . I bet if you go back under there and remove the header and dp then attach them together first and get a good seal then reinstall without using them tabs it should work. Well mine worked.
            yuo guy have any problem puttin the a4 heat shield..?? it seem that i cant put in the heat shield..
            MY 1n2 CB7
              the heat shields didn't look like it was gonna be perfect so i just used some header wrap
