this is a repost, i dont think anyone saw it in the sticky but here is the link
http://www.cb7tuner.com/vbb/showthread.php?t=22253
quick question, in the diagram by cpmike, what is he talking about with the pins and pin numbers?, i recently acquired a set of 90 foglights and i was lucky enought to get the interior oem switch. and the relay, is their a specific relay that i have to get, when i went to the store i saw one, it had 4 pins but no wiring diagram so i didnt buy it. then i saw a whole fog light wiring harness but when i looked at the diagram it had its own switch, which i dont want. so basically im pretty confused. i figured that on the switch there are five wires, 2 would go the the actual fog lights, 1 would be a ground, 1 would be a power from the battery, and one would act as a remote wire (im good with radios and audio). now i am guessing the relay would supply the power to the remote wire. my whole understanding of a relay is that it has 4 wires, one ground, one constant power, one wire out (i guess to the switch), and one wire in (to let tell relay to allow the constant power to go the wire out)
i could be completly wrong but if im right i need to know about the pins on the relay. also did you guys get 55w or 100w bulb (i dont wanna burn the switch), i want mine to be yellow, like the color of the fog lights on lexus cars.
