Running Rich
    Running Rich
    hey im in need of some help, my cb7 is running pretty rich and it blows black smoke out of the tailpipe so i am wondering what it could be that is making it run so rich? its a 91 lx with 145000 miles and i recently changed the water pump timing belt and other belts and seals, im not sure if that would really affect anything
    well any help would be greatly appreciated
    are you throwing a check engine light and when was the last time you changed your O2 censor?
    Click Me
      Check timing of the engine
        No CEL is not on and i havent changed my O2 censor, mabey ill try that
          ok ill try that too im pretty sure its timed right, wouldnt there be other symptoms of having it not timed right though?
            could be a faulty or leaking fuel injector, bad spark plugs, ignition timming, ect. later.
            Avoiding dirt at all costs
              i had first thought it was a fuel injector, because it was smoking black before the timing belt and water pump change. How can i check the injectors? ill pull out the spark plugs to see if they need changing also thanks
                check the condition of the plugs first. look for one or more to be extra clean than the others. this would point to injector leakage.
                pull out the injectors and check for a clean spot inside the intake manifold. (you should probally get a manual to follow the fuel relief procedures)normally there is black/brown gunk inside the intake runners and if the gas leaks around the injector seals, it will clean that goop away, so it will be super clean in one spot vs the other runners where there is no leak.
                a clogged air filter could also cause your car to burn to much fuel. later.
