F22b1 sohc vtec HELP
    Ok I found someone who has a f22b1 motor, sohc vtec accord engine obviously, and i can prob get it free or for really cheap, is it worth it, will it be way better than my f22a6 engine? Can I get alot more out of it than my engine? Like reach better 1/4 times etc. Or should i just save up hella money for h22, im kinda on a low budget though, but would i be pretty happy about the potential of this engine? Please I need some feedback, I need to decide, all the advice i can get will help!!!
    "Mind Over Matter, If I Don't Mind, It Doesn't Matter"
    http://www.cardomain.com/ride/2049267
    its got 145hp so minor hp boost. STill takes boost pretty well like our f22aX. If you can get it dirt cheap i would get it and boost it. acclude91 has one if I remember and he ran some pretty good times with one.
      So if i boost it or fix it up in anyway, will it have slightly more output than the f22a6 motor, I know there pretty similar except one has vtec and the other doesn't so would i get a little more out of it because it has vtec on it?
        Sure? IT depends on the tune and on those motors you can barely feel VTEC kick in well I didnt on my buddies old 5gen. But it has potential I would do it.
          NAiL05 is right, you can barely feel the VTEC on thoese motors, but it is good for boost, and with the money you gonna spend to boost it you proly could of had an H22.
          Will's Accord
            So its probably not worth it then?
              If you have alot of miles and just want something new than yes, but if your looking for way more HP than your F22A6 than no. Besides if your getting it for free than why not do it.
              Will's Accord
                Im just looking for 200-300 horsepower range with turbo or supercharger, would it work better for that range than an f22a6, that mostly what i want to know, and also is the swap difficult, i heard it was harder than the h22 swap online
                  Its actually not. Acclude91 did a complete write up on it somewhere one here. I think you just gotta swap two pins (wiring up vtec/oil press) and cut the driver side mount up a lil and the rest should be easy to do. Id get it. That motor will get you past the 200 mark for sure on boost just as the f22a will.
                    So the easyier way would be just to swap the head & ecu right? Just wire up the vtec/oil pressure engagement?
                    89 Acura Integra 1.6 LSt (Daddy's Boost Toy)
                    94 Honda Accord 2.2 EX (Daily For Now)
                    04 Chevy Suburban 5.3 LT (Kiddie Haulin Pimpness)
                      No the head is a bitch to swap. If you were gonna do it buy the motor. I wouldnt even bother with the head.
                        Ya I saw a forum on another site about the headswap, it can be done but from what I read it is not worth the trouble, lots of modification, just get the whole engine swapped would be much easier.
