As a member of this community, you are expected to know and follow the rules. READ THEM HERE!
Car Smokes
    Car Smokes
    Hey i put a prelude engine in my 1991 accord and replaced all seals and gaskets, etc. to be sure it wouldnt be leaking. Now when i crank my car up it smokes excessively out of the tail pipe. does anyone have any idea what could be causing this? I thought it might have been my plugs so i bought brand new ones and it was ok for a minute or so then it started back. My ignition coil also has gone out and i bought a new one of those and now i think that one has gone out. What could be causing the ignition coil to go bad when its new? and when the car cranks what could be causing it to smoke excessively?
    1991 Honda Accord
    www.animatedimages.org
    did the old plugs have oil on em?
    You have been defeated by a car with child locks, how embarassing...
    "I noticed my f22 felt "healthier" until it blew up." <Myk>
      no they looked pretty clean but worn out. my dad thinks it is the valve seals thats causing the smoking. but my dad and i are both stumped on whats causing the ignition coil to go out twice already(the old one and the new one)
      1991 Honda Accord
        What color is the smoke. How does the car run?
          well before the coil went out the other day when the car ran it ran fine...idle fine and everything. the smoke was a greyish color and lots of smoke....looked like a huge fire with the clouds of smoke
          1991 Honda Accord
            o-rings?
              i think i am going to replace everything the valve seals ,orings, etc. thats what my dad said would be best. does anyone have any insight on the ignition coil going bad even though its brand new?
              1991 Honda Accord
                might as well swap the engine, i had the same problem and i bought a f20a dohc engine. cost me about 800 total with the labor.
                  i just bought this engine and the engine itself cost me $900 not including labor and everything...
                  1991 Honda Accord
                    oops i didnt see that u had a prelude engine, what kind is it? h23 or h22?
                      F22 DOHC
                      1991 Honda Accord
                        id also check the ignition timing. when you put the dizzy in, did you set the crank to tdc? could be timing issue?
                        also just some advice..if you put in a new /used motor id spend the extra money and pick-up a new dizzy from ebay. it comes with new coil, ignitor, and everything. i bought two off ebay from a guy flying-pat out of plattsburgh, ny.
                        ive never had a problem with the dizzy. i got oone for my accord and one for the cr-v. its cuz once the oem bearing goes bad you screwed. just my opinion.
                        and again from your other post..its your ignitor most likely. it can take out a good coil.
                        btw..look at your dizzy and give me the part number..should be like td-55U number.
                        regards x
                          yea I agree I would also check your timing and the igniter, do you know if
                          that engine ran fine in the donor car?
