JDM head lights
    JDM head lights
    http://www.cb7tuner.com/vbb/showthread.php?t=28448
    What kind of headlights are those? Maybe a link to somewhere that I could purchase them? Greatly appreciated. Thanks
    they seem to be diy black housed head lights, there are some on ebay occasionally.
      they are stock headlights with the following modifications:
      1. black corner lenses, you can get them on ebay
      2. inner housings painted black. search this site (especially the DIY section) for guides how to do "blackhousing" headlights.
      3. yellow high beam bulbs
      4. DRLs (daytime running lights)... they turn the highbeam bulbs on at low intensity at all times when the car is running, but turn off and go back to working as regular high-intensity highbeams when you turn the lowbeams on. this is a standard feature on canadian cars, and you can rig up a DRL control module to make your headlights do the same.
        is the DRL part expensive off say, a wrecked canadian cb7? And is it hard to install?
          http://www.andysautosport.com/produc...88&_v=vmd00185
          is those similar to the corners that he has?
            http://www.andysautosport.com/produc...68&_v=vmd00185
            and are those the similar bumper lenses?
            sorry im stupid...
              yes and yes. but check the applications, the corner lenses you linked to are for 92-93 and the bumper lenses are 90-91. make sure you get the correct years.
              i had DRLs for a while, accordztech and myself figured out how to get the module made by Insight hooked up. they used to be common on ebay (search "Insight DRL" or at least... "DRL module" and you could probably find something that you can use) but i think the actual Insight ones are hard to find now. as far as getting the parts from a canadian CB7, im sure you could, but youd need to get all of the relays and control boxes and connectors. and where they all are, i have absolutely no idea.
              FYI, you can edit your existing posts in case you want to add/change it, like for example, the three posts above.
                good lookin'.
                I noticed the 92-93 thing, copied wrong link. Thanks abunch
                  Hey Corn Flakes, actually the DRL Module here in Canada, i live in Toronto, is kinda expensive in terms of everything you need. If you go to the dealership expect to pay quite a bit, but if one were to go to a junk yard its pretty cheap. I can find out prices for you if your interested once i get off work.
                  [JHM]H22CB7
                    dude it would be nice if you could get me some info. I dont mind buying it from a junk yard. Let me know, please!
