Time for an oil change
    Ok so my baby is due for an oil change. Only thing is I wanna do it myself so here's the thing. What kind of oil do you recommend and for two, where are the jacking points for the Accord DX coupe? I have one hydraulic jack thats good and two two jack stands.
    1992 Honda Accord DX
    Coupe 5spd
    2.2 liter I-4 (code: F22a1)
    125hp @5200 rpm 137 lb/ft @4000 rpm
    (\__/)
    (O.o )
    (> < ) This is Bunny. Copy Bunny into your signature to help him on his way to world domination!
    i think on my blue accord it said to use 5w30.
    if it's a high mileage car, i would look into using a synthetic blend as it's not prone to thermal breakdown.
    but personally i use Pennzoil for all my cars/trucks.
      ok and waht about the jacking points?
      Coupe 5spd
      (\__/)
      (O.o )
        there shud be sum small lips of metal behind the front tires oin the rocker panel
        Hold On Not Done Accelerating
        Had One Never Did Again
          Read your owners manual....The information is all there.
            Use the front crossmember to jack up the front of the car. It is at just about the center of the car, and has a loop at the end. Jack that up and place jack stands at the points right after the tires so you do not kill yourself.
            Gary A.K.A. Carter
            [sig killed by photobucket]
              xxxxxxxx22000000
                isn't that loop used for towing?
                  Listen to the fella
                  ...adjust accordingly
                    Right now I am using Mobil 1 5w-50 (100% synthetic) and response is little heavier compare to Mobil 1 5w-30 (100% synthetic). So next time I am going to try Mobil 1 0w-40 (100% synthetic).
                    1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
                    2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
                    3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
                    4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
                    5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
                      Originally posted by gdout90accord
                      xxxxxxxx22000000
                      now if only my car came with an owners manual. That would have been the first place I looked.
                      Coupe 5spd
                      (\__/)
                      (O.o )
                        you should buy a haynes manual at autozone or somthing .... it will really help you alot on everything about your car
                          I get payed today so I'll probably pick one up today thanks
                          Coupe 5spd
                          (\__/)
                          (O.o )
                            Always have a manual handy itll help you out a lot with the basic stuff like this.
                              XXXXXXXXXX22222222222222
