Heater Switch Stuck!
    My Heater Switch (in my 4th gen.) is stuck. The car is now blowing hot air...constantly
    On my way home, my friend turns on the heat to full. After about 30 seconds, I say "this is retarded," and turn it back to the coolest setting...or so I thought. The switch had a bunch of play in it, and, when I got home, it ended up just popping right off, exposing the metal thing that the plastic knob is attached to.
    I tried using plyers to --gently-- twist the now knob-less switch back to cool. When twisted counter-clockwise (i.e. cooler), it doesn't budge past a certain point. It seems happier to spin clockwise (i.e. hotter).
    Bottom line: it's still just blowing hot air, and I can't adjust the knob with normal amounts of force. I'm royally fubared.
    Someone please help! It's summer! I needs my cool car!!!
    1991 Honda Accord EX (Canadian)
    you gotta take the unit out and in the back there is a metal cable its probly just jammed up..\
    .............................-----------------93 Ex Coupe[/COLOR]-----------------
    My CD7
      I had the same problem with my car. most likely the knob is broken. this is a very common problem on cb7s and CDs. you can find replacement knobs from Auto Zone (and other parts stores) for about $8 or so.
      My Accord
      www.d1imports.com
        He said he pulled off the knob and tried turning the rod that holds it manually and still didnt turn to a certain point. So its not the knob. As mentioned you will have to pull out the whole unit to see what is wrong back there.
          i understand. i had the same issue. I tried pliers as well. (not enough force or leverage? since there isnt enough space for a decent set of pliers). Since he will need new knobs anyways. he might as well get give it a try before ripping apart the dash?
          My Accord
          www.d1imports.com
            Look down by the firewall in the engine bay on the left side. Look for a hose... and a little cable attached to it. The cable could have snapped which makes it not go on. Just move this peice with your finger and you will be fine...
            Hope it helps
