im almost finished doin my clutch job and i have drained lots of coolant in the process. i was wondering if i will have to flush out the whole system and refill it or can i just fill it up as it is? i have a bit of coolant left in the resovior tank. thnx
coolant flush
Ok on the bottom of the radiator there is a plastic screw its called a petcock
for real thats what its called, make sure the radiator cap is off and unscrew it and all the fluid will come out of the radiator. If you cant find it you could just take the lower hose of the radiator. As for the overflow just remove it and dump it all out, good luck
If you wanna really clean your system take off your upper radiator hose and get a longer one or you can use your stock one but its gonna get everywhere in the engine bay. But yea get a garden hose and put it on the radiator and turn on the car and you should have a decently big water gun that dont shoot far and let it run until its clear plus gets the dirty bits out. But I recommend draining most of it first before doing that.Originally posted by LinXyou drain the resevoir tank by unscrewing the top and just pulling it out and dumping the fluid in a safe place.
yep, i did that also but i only disconnected the top hose and took out the radiator plug and it just comes rite out. do it when your engine is cool to the touch and don't leave the engine running for longOriginally posted by NAiL05If you wanna really clean your system take off your upper radiator hose and get a longer one or you can use your stock one but its gonna get everywhere in the engine bay. But yea get a garden hose and put it on the radiator and turn on the car and you should have a decently big water gun that dont shoot far and let it run until its clear plus gets the dirty bits out. But I recommend draining most of it first before doing that.
