Engine help!
    Engine help!
    I have a 90 accord and my engine is acting up. I did a compression test and found the my third cylinder is has zero compression. Is there any advice anyone can give me to what i should do?
    you can do a rebuild or choose from a selection of motor swaps. junk it or part it out. later.
    Avoiding dirt at all costs
      if you know how to work on a car yourself you could always visit a local junkyard and pick up a used motor. Use it and your stock motor to do a rebuild. Or if you're into performance you could always rebuild the junkyard motor with some nice internals
      You COULD try re-torquing the head bolts, but there's very little chance that that would help at all, and even if it did it would be a temporary fix at best.
      I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
      "Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
      CB7: The Movie TEASER VIDEO
        Thanks guys
