I've been trying to reset my ECU to pick up my new MAP sensor, but I pull the negative battery cable, I pull the ECU and radio fuses out of the under hood box, and wait 20 minutes. It still seems that it's not resetting though because my clock still has the right time and my car is still throwing the same codes as before.
Trouble resetting ECU
I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
Tags: None
it literally takes only 15-20 seconds though.....if you have a code, you should notice that they're gone after that, but if something is wrong, they WILL come back after a minute of idling.......it only clears those that don't really applyOriginally posted by GREENCB3try taking out the 7.5 amp fuse in fusebox underhood that says radio something for 1 minute.....and on the 7th day, deevergote rested and called his mom.
fuk it, take off the positive and negitive for a few minutes...haha no way it should keep memory...
sometimes on the new cars, there is a reserve in the computer..so i disconect everything and then turn the headlights on to drain anything else and its fine.
if that dont work you have a rat on the treadmil in your car running to make power for ur clock hahahWhat makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
