Could it be the Timing Belt
    Purchased a 90 Accord Lx a couple of weeks ago.....How do I know if the timing belt has popped.....It sounds like it has.....All it will do is turnover...But It makes a winding noise When it turns over....Any Suggestions on what it could be.
    does it turn over really fast?
    pull back the upper timing belt cover, and see if you see the timing belt on top of the cam gear.
      Yeah seems to be turning over pretty fast...I put a new valvecover gaskett on the other day..and the timing belt was still there....
        Check your starter?
          Well if you can see it sitting on the cam gear then it is still intact which is good news. Your car is either not getting spark or gas so start from there.
          jdmCITY.com
            have somebody look under the hood while youre starting it, see if the belts are all spinning... if not, the starter solenoid may be bad...
              Originally posted by NAiL05
              Check your starter?
              I did not even think of the most obvious, that your starter is not engaging the flywheel, which easily could be the problem.
              jdmCITY.com
