my shifter is messed up now because i accidentally took this part off. i dont no wut it is called. its attached to the transmission and is where the shift linkages are connected to. anyone know wut its called? thnx
need help with part name
picture??
put a thin layer of silicone gasket maker along the edges, and technically it just drops on, and then you install the four 10mm screws. theres a piece that slides back and forth inside of the transmission, the shift arm cover has a peg sticking down that needs to be centered in the sliding piece...Originally posted by jas_r34does anyone now the procedure to put this on
i took it apart n tried to put it back but whenever its back on, all the gears wont work, only a few.
ive been trying that for days now and the shifter still does not go into certain gears.Originally posted by cp[mike]put a thin layer of silicone gasket maker along the edges, and technically it just drops on, and then you install the four 10mm screws. theres a piece that slides back and forth inside of the transmission, the shift arm cover has a peg sticking down that needs to be centered in the sliding piece...Hold On Not Done Accelerating
Had One Never Did Again
