sway bar ??
    sway bar ??
    The end links on my front sway bar is bad they have been for a while Im finaly going to fix them and I found the frame bushings for them on ebay there from energy suspension and there polyurethane. My question is the ad says there for 25mm sway bar I was wondering If anyone knew what mm our sway bars are I no longer have a set of calipers to measure them and im stumped also on polyurethane isnt it best to put some grease on them so they wont squeek. THANKS
    If they have the bushings for our cars listed at that size, then I would assume that is the stock bar size.
    When I installed a rear sway bar, the kit came with some grease if I am not mistaken. I would guess that some moly based grease would work well. Im not sure if there is special grease for polyurethane bushings.
      I actually got a set from Advance and replaced mine....THey werent that expensive and were easy to replace....As far as size, I have absolutely no idea!!!
      07 Kia Sportage (Her car)
      91 Accord EX (My car)
      04 BMW R1150RS (My bike)
        Bar diameter doesn't matter for end links.
        2003 Maxima SE Titanium Edition
        1993 Suzuki GSX1100F 136bhp
          Well I think he is replacing the endlinks AND the frame mount bushings.
            yes I need the right size mm for the frame mounts. thanks
