drive gear/speed sensor
    how do u get the drive gear "the thing that the speed sensor sits on "back in the grove
    move it around untill it fits.
      When I changed mine, I put the key back in the slot and moved the speed sensor till it slid down. After you stick the key in the slot, you can kind of see how to get it back on there.
        im talkin bout the gear not the sensor but i dont know if its electrical prob cause when i put new sensor on there and took it for a test drive mph went up and drop back to 0 and has been doing that so whts the prob i know the gear isnt stripped
          You know ..I just did mine yesterday .. I replaced the entire drive shaft .. switch and all.
          Re-set the ECU? I dunno why your's isn't workin .. you throw a CEL again as well?
          I knew I changed the whole assembly for a reason .. hope you get it figured out!
          A Hui Hou !!!
          Tomi
          My CB9/Wagon Thread Start to Finish:
          http://www.cb7tuner.com/vbb/showthre...ighlight=wagon
            how exactly did u get the whole shaft back in right please tell causemine shakes when imove sensor
              I dunno what you mean by shaking .. mine just dropped in .. and bolted down ..
              Look at the gear *inside* ? Maybe thats fugged up? I sure hope not ..
              A Hui Hou !!!
              Tomi
