Is it dificult to replace my injectors on my f22a1?
injector help
No. Just make sure you get new o-rings if your old ones are effed up.
Remove the gas cap where you fill up. Lower the fuel pressure by loosening the banjo bolt on the fuel rail. Replace O-rings and make sure you lube them up with some oil. When you put the rail back on, make sure you don't jam the injectors too much or else the seals will go bad and you'll have to do everything over again. Don't over-torque the fuel rail nuts is basically what I'm saying here.
...adjust accordingly
