Ok, this question may sound dumb, but I removed most of the "carpet" like material from the sides of my trunk yesterday and I fail to see any place to mount my rear strut tower bar too. Anyone have any pictures of one installed so I can see where the mounts are?
Installing rear strut tower bar?
I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
Tags: None
You have to remove the two nuts that hold the strut in place. Theyre pretty much behind the rear seats but you can reach them from the trunk too by removing most of the carpet. Remove the two #17 nuts
http://www.hondaautomotiveparts.com/...SHOCK+ABSORBER
...adjust accordingly
a pic would certainly help wonders. I've installed these on cars before and usually it's no hassle at all......but I've removed the trunk lining and the back seat completely and I still don't see anything over the tires except for a metal bump. They must be well hidden or tucked away nicely.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
Just behind the back seat..remove the carpet..
:NOTE: does not require the removal of all interior
you can follow the bar acorss and see where it mounts.
remove nuts, install brackets, put nuts back on, and install bar..its that simple
-1992 Accord EX H22 234whp 185wtq
-1993 Accord EX SOLD
-1995 Accord EX Wagon Daily Driver
-2012 GMC Canyon V8 4x4
ok, gotcha. As you were posting that last reply I was inside my car ripping at it from inside. When you say "right behind the seat" you aren't kidding. In fact it's nearly impossible to install from the trunk, my recommendation to anyone else is to just fold down the back seat and pull off the two little plastic panels (one on either side of where the seatback rests against. That's where the tops of the struts are
