Transmission problem
    My brother has a cb7 and said his tranny has been not going into gear and also when hes driving it will slip so bad that it just revs up like its in neutral and then will catch again and throw his head back. Is this mean the tranny is shot? If it is shot how hard is it to install a new tranny? I am rather mechanical inclined. I work on jeeps and offroad vehicles alot.
    has he ever replaced the clutch before? that's what it sounds like to me.
      Its an auto
        Anyone?
          Your prob low on trans fluid by the sound of it. Check levels and fill it up if needed. Might have a leak somewhere.
            replace the cable that goes from the carb to the tranny.
            93 Accord LX Sedan (sold)
              I would still check the fluid first which is a lot easier than tearing that up first since thats what it sounds like his problem is. And its really not hard and cheaper.
                I had the same problem. the messed up cable that goes from the carb to the tranny was a little torn. it was causing late shifts which made my tranny heat up & make the fluid go bad.
                the cable can cause bad fluid.
                the cable I got for like 120 or somthing
