performance
    performance
    i have a 93 accord ex 2dr a friend and i will be pulling the motor this winter im only looking to rebuild motor and bump it to 200 to 240 hp turbo chargers are a bit expensive where should i start im at a stock 140 hp now. i would also like to know where i should look for some colered calipers and chrome or colored engine parts.
    before you built the motor get an intake then exhaust and header. Get a delta cam, high compression pistons, as long as you have the engine a part why not just get the whole motor ported and polished along with a balaencing. 15 for the cam pistons un sure 20 for intake 20 from port and polish maybe another 5 to 15 hp from the balaecing that should put you near 210 hp. Also you may want to throw part of upper manifold from an h23 onto your intake. Those are just some ideas. Your best bet would do a search of each componet and see whats best for you.
    Click Me
      for the price he would have to pay that he should just go h22 thats 200 right there
      U dont work U dont eat
      U dont grind Udont shine
      1st car 90 CB7 lx auto coupe
      present car 90 CB7 ex clutch coupe
      1st motor f22a1 2nd motor f22a4 present motor JDM H22a with m2b4 trans
        If your lookin for numbers in that range your easiest bet is turbo..NA is gonna cost you unless you swap in the h22a as mentioned. Since your rebuilding the motor I would say get you a 16g and tune that properly and it well get you well over 200whp.
          ya build the f22 then boost it with a 16 and tune it properly and you will run nicely its really not that bad on the wallet so have fun
          http://www.2kracing.com/index.php/cPath/4_60?osCsid=9dfebfe0d4f332b5c7b3498b65c09864
          http://www.naganojapanese.com/jdm_f22b.htm
