Coolant temp gauge
    Coolant temp gauge
    Lets get to the point. under heavy acceleration my coolant gauge fluctuates any Clue as to why i did search and came up short
    fuck the bitches that stole my car jan/1/2006@7am from montesano wa updated: The Warrens from Malone Wa were found guilty for possesion of stolen property in the 1st*and were ordered to pay $2489.69 in restitution, only cause the shell was not found
    R.I.P.
    Vouches from: Snailin91, Caution, 2G6, Jdmf23accord, Boosted_StinkyNuts
    therse a 1-wire sensor right under the dizzy cap. try unplugging it and cleaning it. also clean the part where it goes on.
    you're in montesano? do you know chan? ive been there and its so small you have to know him!
      Does it go down or up?
      when is the last time you flushed your coolant
        yah I know him thanks for the tip
        R.I.P.
          Both coolant is new rad is new
          R.I.P.
            alot of people say thats a sign of a bad water pump.. BUT
            i just had this problem, make sure you get a OEM honda thermostat, change the one wire senser and the one right behind it!
            MAKE SURE YOU USE OEM HONDA PARTS. everything else is Garbage when it comes to the cooling system
            I wound up changing everything all of the sensors, the thermostat, and the water pump, and it was still screwed over.. come to find out it was the Cheapo napa Thermostat
            .............................-----------------93 Ex Coupe[/COLOR]-----------------
            My CD7
