Tire's scrubbing
    Tire's scrubbing
    On stock shocks and springs, the tire on the rear driver's side was scrubbing pretty consistently (while I exited right corners at speed). I then installed Eibach Pro-kits, KYB AGX shocks (3 front, 6 back), and 205/50-16 tires. I have a minimal drop and firmer springs but the scrubbing on the rear driver's side still persists.
    I'm curious as to why this is only happening on one side. It seems that wear would be even on both left rear and right rear sides of the car so it's hard to imagine what suspension components I should attempt to replace. Any thoughts?
    How far are your tires sticking out of the wheelwell ? My tires were rubbing the little lip on the wheel well just took a rubber mallet and knocked the lip up.
      As he said might need to roll out your fender a lil but looks like you got plenty of wheelgap there. Or check what is hittin if its not that. Hows your rear alignment?
        Def check Rear Alignment
        91 Accord EX (Fresh Look STOCK)
        BIG PLANS on THIS!!!!
        9-12-05 - On
          Alright, I'll have to check out those two things. Thanks for the ideas.
