Help removing clutch pedal. *pics please??
    SO yeah I took off the 2 nuts that hold it on.
    But the cable is still attached to it.
    How the hell do I get this off. I dont have a flashlight so i can't see it well.
    I need to get it off tommrow morning since i sold my 5spd swap shit.
    LMK pics help
    thank you
    wtf someone help me please!
    Ill give you a dime.
      theres two 12mm nuts which you say youve found.
      theres a 12mm bolt at the very top center of the assembly
      loosen the locknut pictured below and rotate the shaft the direction of the arrow until its completely loose from the bracket
      thats it
      [img]http://www.****.com/pics/adjusting_clutch.jpg[/img]
        Sweet thanks. Ill try this now
          thats it
          That's a great pic. I've been meaning to adjust the engagement point of my clutch for a while, but didn't know how to do so. My clutch was replaced (friction disk, pressure disk, bearing, gear set, gear, low friction damper - from the repair log) about 70K ago. There seems to be very little room between engaged and out of gear in the pedal.
          I think I'll give this a try tomorrow. If I mark the original location of the nut on the shaft, and rotate the shaft a turn or two, worst case, I can just adjust the shaft the other way (back to the original location), correct? Best case, the engagement point will come up a bit, and I'll have saved myself some money, and learned something new.
            Agreed!!! That is one helpful picture youve come up with. That helped me out and I dont even have a manual!
            Been a long time. Still alive...
