timing belt
    timing belt
    okae i have searched and nothing seem to answer my question....how do u know if the timing belt is bad...is it like other belt where there's cracks in it.....cause mine still seems to be fine but it's a bit loose...not to loose...it has play...but not to much....and when i checked my integra same shyt...and my other friends EG civic....he's own is tight and he has a B18 motor in it....and i checked my other friends DA(Integra)he's own is tight also no play...and i got my timing belt water pump and motor overhauled about a year ago at my dad's work at honda....and it's a trip cause both friends that have a B Series motor their timing belt has no play and my CB and my da has play...and both are done at my dads work....so is it bad if a have a lil play in my timing belt with no craks?
    Signature removed due to excessive size. Please read the rules before creating a new signature. - cp[mike]
    Change it every 70-80k miles. What I say if you dunno when you changed the timing belt then I suggest you change it. The timing doesnt crack I think it stretches. The only times I have seen them crack is when they just decide to come apart and such.
      yeah but my timing belt was change like allmost a year ago and have less than 15,000 miles on em.....
        Maybe you just need to tighten the tensioner a lil more then. But if its not giving you trouble now I wouldnt bother messing with it.
          ohh okae.....but yeah thanks for the help i appreciate it alot
