94-95 accord?
    94-95 accord?
    are the 94-95 models obd1? im looking into order a f22b and wanted to keep the obd1 if possible. thanks
    yes but wich f22b? f22b f22ba f22b2? sohc or doch, vtec or non vtec
      i was looking at getting the f22b sohc vtec from a 94 -97 accord and was wondering if all the wiring would be just plug and play. and is their a difference in the 94-95 and the 96-97 engines. thanks
        the 96-97 incorated a crank angle sensor by the oil pump assembly bhind the crank pulle and all that good stuf, you can still use the 96-97 motor, it would just all be a plug and play thing, they are obd2a....if not, get a f23 sohc vtec 98-00 accord, that would be nice, dont get the ulev model, get the one that just says vtec, but gotta be a f23....it is obd 2b but will still just plug and play!
          iso your saing i can put a motor from a 98-00 accord in a 90 model and it will just plug in?
            f23 -- lil bit better yes. Good question though about plug n play. I'd think with either that or the f22 vtec you'd still need the right ECU to trigger the vtec? Who will clear this up?
              just use a VAFC, to trigger your vtec, that'll work "in theory" right?
                you can put in a 98+ f23, with 94-95 intake manifolds and sensor, and 94-95 P0A vtec ecu keeping everything obd1 but you still need to add a couple wires to your harness for vtec.
                if put in a 94-95 f22b1 w/ the P0A ecu everything will bolt right up you just gotta run wiring for vtec.
                  Yeah I wouldn't waste my time putting in the F22B1. The F23 VTEC is a much better choice if you really like staying SOHC.
                  I'd personally get a F22B DOHC but that's me.
                  my $0.02
                  (RIP)1993 LX Sedan
                  Frost White Crew Member #36
                  JDM Beating Stick Owner #1
                  My (old) Ride
                    is the f swapp that much cheaper than an h swap? man h22's go for so cheap nowadays unless theres other reason why u want an f22... sohc.. =T
                    Frost White CB7 Crew #28
                    RIP cb7
                    99 taffeta white ej8
                      i dunno wut you talking bout h22a go for cheap. cuz h22a in miami is 2,200 dollars with everything. and 500 extra for labor installation. so i wouldnt call that cheap. that's about more than the bluebook for my car i think.
                      DEFJAM
                      MY RIDE ON CB7 DEFJAM on 93
                        obd2 dizzy will need some wiring, I belive. and the 5th gen vtecs had an internal coil, but im unsure about the 6th gen vtec. If you have to change you will need to modify the coil wires. I think I heard somewhere that the distributor you already have could be put onto the f23.
                        spin city
